Need a bit more info on what you are attempting to get out of this build. What supporting mods do you have on the 4AGZE? Cams, P&P, engine management, etc.? What is your expected power band - you want more low end power, midrange, or big power on-top? What turbo where you running before?
There are two different Volvo TD04 turbos - one is a TD04 the other is a TD04HL - the HL variant is supposed to be the better of the two. Both would be also be too large for a 1.6L engine, unless you have the mods to support it. Even the DSM crowd, have a tough time getting this to work out.
T04 - are pretty common for MKIII and MKIV Supras, again might be too big for a the 4AGZE, depending on your mods.
T3/T4 hybrids are your best bet - from the ones you've listed here. Even then, it might still be too big. This doesn't even touch upon A/R, wheel trims, compressor maps, etc.
