p0171 DTC ON MY 2000 COROLLA - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2009, 12:08 PM   #1 (permalink)
View ancong888's Photo Gallery
Hi,
I got a engine check light on, and I check that is p0171 with code scanner,
the live datais below:
calculated load value: 18.82%
ECT: 93*C
STFT-BANK1: 0
LTFT-BANK1: 21.88%
ENGINE RPM: 656
VSS: 0 KM/h
IGNITION TIMING ADVANCE#1 CYLINDER 15.5 deg
intake air temp. 28*C
AFR FROM MAF SENSOR 2.2 g/s
absolute throttle position 10.59%
bank 1 - sensor 1 0.05v
bank 1 - sensor 1 0.78%
bank 1 - sensor 2 0.09v
I did clear up the MAF, but after a few day drive, light on came up again,
and then I changed the MAF, the engine check light on after 2 weeks.
can anybody help me to figure out what is the problem on my car.
thank a lot
mike
ancong888 is offline   Reply With Quote
Old 05-26-2009, 03:32 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Possiblites associated with a P0171 CEL:
- leak in the air induction system
- clogged/gummed up PCV / hoses
- dirty or gummed up injectors
- dirty MAF sensor
- faulty ECT coolant temperature sensor
- reduction in fuel pressure (clogged fuel filter / faulty pressure regulator)
- exhaust leak
- short /open oxygen sensor (short / open in heater circuit)
- faulty ECM
- multiple ground loops / bad chassis grounds
- bad tank of gas
I'd just run down the list, hitting the ones that you can check visually first (i.e., free fixes), then dive into a more through diagnostic. Hard to tell from the snapshot you posted - if the car is running fine, aside from the CEL, no stubbling/hesistantion/etc. - then I'd either try a different gas station and/or add a bottle of decent fuel injector cleaner. Just to see if the code comes back.
The Following User Says Thank You to fishexpo101 For This Useful Post:
nemesisre (02-25-2012)
Old 05-29-2009, 02:14 PM   #3 (permalink)
The P0171 Coming Up Again
Freeze frame: P0171
calc.load 45%
ECT 203*F
STFT B1 2.3%
LTFT B1 39%
ENG RPM 2320
SPEED 35MPH
IAT 86*F
TODAY, MY DTC COMING UP AGAIN AFTER 2 WEEKS.
ABOVE IS THE FREEZE FRAME.
DID THOSE DATA CAN HELP TO FIGURE OUT SOMTHING?
NEED HELP
MIKE
Old 05-29-2009, 03:26 PM   #4 (permalink)
Gearhead
Do you have datalogging capabilties? What have you done maintenance wise so far?
The only thing that gets me worried is the STFT and LTFT being quite a bit more than +/- 25% and I'm assuming that you're not WOT at that point (actually one of the requirements in order to run the DTC - TP sensor not past a certain point, speed is less than some threshold, temperature, mass air flow, engine speed has to be between a certain range).
For those that might not understand - STFT (Short Term Fuel Trim) and LTFT (Long Term Fuel Trim) are "learned" values by the engine computer or ECU/ECM/PCM (Engine Control Unit / Engine Control Module / Powertrain Control Module). STFT is a dynamic correction to fuel to keep the engine close to stoichiometric or 14.7:1 Air to fuel mix (optimum mixture for efficient combustion). That shouldn't vary too much past +/- 10% but it will vary a lot. LTFT follows the trends calcualted from the STFT - that trend is basically the culmulative average of the STFT readings over time. They will vary, but anything over +/- 25% (STFT + LTFT) is out of spec for this car.
How does the car run otherwise? Any trouble starting, takes longer than usual to start? Does the code come on when the gas tank gets low? Are you running an after market intake, drop in panel filter?
Old 05-29-2009, 04:02 PM   #5 (permalink)
115k miles
01loadedLE's Avatar
Gameroom cash: $123100
View 01loadedLE's Photo Gallery
Fish, could a clogged cat converter get the computer to think the fuel mixture is too rich and cause it to spray too lean where it would trip that code?
How many miles on it 888?
I'd rather be flying.
Pics & info on my 01 LE
01loadedLE is offline   Reply With Quote
Old 05-29-2009, 05:09 PM   #6 (permalink)
Gearhead
^^^ Possible, if it was really clogged up, cause exhaust gases to backup and lead to a misfire. That extra fuel would "eat" up whatever oxygen is left in the resulting exhaust mix and the O2 sensor will read a lean condition. I would think it would trip a misfire code - but not always, sometimes the ECM gets fuzzy in its thinking.
Old 05-29-2009, 07:11 PM   #7 (permalink)
115k miles
01loadedLE's Avatar
888 what gas brand and octane have you been using? Im wondering if you have been using non top tier gas brands or higher octanes to where it could have eventually fouled the converter, injectors ect.
Old 05-30-2009, 06:34 PM   #8 (permalink)
Try To Answer Some Of Question
How does the car run otherwise? normal
Any trouble starting, no
takes longer than usual to start? no
Does the code come on when the gas tank gets low? no
Are you running an after market intake, drop in panel filter? no understand
What have you done maintenance wise so far? #87
What have you done maintenance wise so far? 1. clear MAF no good
2. change MAF
THANKS A LOT FOR HELP
