exhaust camshaft timing mark - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2009, 04:34 PM   #1 (permalink)
00 rolla VE
View huangxin's Photo Gallery
Hi, I took my engine out yesterday for the rebuild and today I'm taking it apart. After I took the timing chain off I saw that the exhaust timing gear has 3 marks on it. 2 dots on opposite ends. one with "IN" marked beside it, one with "EX" marked beside it, and the third dot marked equal distance between the 2. Does anyone know which dot I should hook the #67 link on the timing chain to?
The intake assembly only has 1 dot, the 3 dots on the exhaust gear confuses me.
Thanks in advance.
huangxin is offline   Reply With Quote
Old 05-26-2009, 05:24 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
According to the FSM - the #67 link mark should line up with the double dot mark on the exhaust side. The intake's single dot mark should then line up with the #53 link mark.
Old 05-26-2009, 05:42 PM   #3 (permalink)
00 rolla VE
the 3 dots are on the same timing gear
also, another problem...I was taking the head off and 1 head bolt stripped...I can still get the hex head in, but it's not tight enough for me to remove it. Anyone know where I can have this bolt drilled out? and how much would it cost?
Old 05-27-2009, 10:29 AM   #4 (permalink)
Gearhead
So there is not a mark with two dots sitting right next to each other, close together?
Well initially, you should set cylinder #1 to TDC/compression by lining up the single doto n the intake with the dot with EX next to it on the exhaust side. They should be set to sit in the same horizontal plane, dots as close as possible.
Old 05-27-2009, 11:06 AM   #5 (permalink)
00 rolla VE
yeah, i tried to line up the mark last night and figured it out. thank you very much for the info.
