EVAP issues are pretty common on the 8th gen Corolla. Is it safe to ignore? Depends on what the code was - sometimes it is a worn gasket on the filler cap, other times it might be from overfilling the tank (do not top of the tank, bad for the vapor canister). If you have smog inspections, you need to fix that EVAP issue to pass - EVAP deals with emissions. I would have it checked out - as it could be something you really need, like a cut-off valve or similar.
I'm with huangxin on the brakes - if you knew you were metal on metal - you should have stopped driving the car and get that checked out ASAP. Brakes are not something you want to wait on, if you need them now, get them. Could have a situation where, instead of $40 for a two paris of shoes for the drums - you're now looking at $15-$55+ a drum (either turning them down or replacing, if they got scored too deeply), plus shoes, and hardware. Also braking load will shift forward, since the rears are no longer pulling their weight. Braking performance will automatically suffer in response.
As for the exhaust - depends on where the leak/hole is. If it is not too close to the exhaust manifold and the pressure isn't too high - you might be able to patch it temporarily until you get the other, more critical items fixed.
Weatherstrip - that is almost always a dealer item - aftermarket may not give a satisfactory performance (doesn't fit right). Try a body shop and see if they can set you up - they have many more sources for parts, they might be able to order you one.
