idle problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2009, 01:36 AM   #1 (permalink)
View rolla99oshit's Photo Gallery
idle problems
Sometimes the car idles at 500 most of the time, sometimes it idles at 600 and sometime 800. These idles were observed when the car was normal temperature throughout all 3 different rpm numbers. Is there anything wrong with my engine?
rolla99oshit is offline   Reply With Quote
Old 05-28-2009, 01:18 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Idle will move a little bit - but not that wide of valves. What have you done to the car, maintenance wise, so far? Could be nearly anything - from clogged injectors, to a leaky intake/exhaust, vacuum leaks, gummed up TB, fouled plugs, bad plug wires, sticking throttle cable, etc.
Old 05-28-2009, 01:21 PM   #3 (permalink)
I have seafoamed the car? but the car suns smoother after i seafoamed it and it was still idling low before seafoaming it
Old 05-28-2009, 01:46 PM   #4 (permalink)
Gearhead
Did you pull the plugs after you seafoamed it? Seafoam treatment tends to foul the plugs easily - if the plugs are messed up, the car will idle erratically. How about the other stuff under the hood - what other maintenance have you done so far?
Old 05-29-2009, 06:19 PM   #5 (permalink)
I havent done anything with this car
