I think I paid about $13 or $15 for it - don't remember for sure off the top of my head. The Permatex stuff is pretty good (assuming you are using the Permatex Ultra Black Gasket Maker stuff (almost exactly like the Toyota stuff) - I don't think it is a sealant issue as long as you followed the directions on the "tube", not Haynes.
Haynes manual instructions look just like the ones in the Factory Service Manual - as long as you followed that for the bead placement and let the RTV set as described on the tube, should be OK.
Really difficult to gauge how much is correct to use - bead width is one measure, but takes a little more than that. As long the sealant material didn't all squeeze out - should be OK. Some sealant would squeeze out - but not so mcu that it will drip off the mating surfaces. The Toyota FIPG (Form In Place Gasket) sealant is almost like a create-a-gasket. Has a particular "tack" time, that should be followed. General RTV (Room Temperature Vulcanization) needs a little bit of heat and moisture (has to "breathe") to fully cure - hoping that you didn't get a tube of Permatex Black RTV, a general purpose RTV sealant - completely different than Permatex Ultra Black Gasket Maker sealant.
Also, did you double check the cover for warping? Possible that is what caused the initial leak. On this engine (1ZZ-FE with VVTi) - most leaks start around the timing chain tension on the back of the head (closest to firewall).
