First need to track oil consumption over time. Find out exactly how much oil the engine is going through. Don't let the oil get low - the car's sump only holds 4 quarts. If you can't see oil on the dipstick, then you are automatically atleast 2 quarts low. Low oil levels in turn really excaberates oil consumption rates. Need to be checking oil levels on a daily basis.
This generation of Corolla has some cars that are known "oil-burners" - some go through a quart of oil in as little as a few hundred miles. Some don't drink a drop of oil over a normal oil change interval. For that many miles on the car - some oil consumption is considered normal - just have to find out exactly how much oil you are using to make that determination.
Some things you can do to less the oil consumption - try a 10w-30 motor oil. Especially if the ambient temperatures are high enough (i.e., no subzero winter cold starts). The OEM recommended viscosity is 5w-30 for most conditions - being in FL - you could use 10w-30 all year round and not see much difference in engine performance / fuel economy.
Some have reported very good results by switching to a high mileage motor oil or semi-synthetic blend / synthetic motor oil. The high mileage and synthitc blends or full synthetic motor oils tend to resist high temperature burnoff that conventional oils see. They generally have higher solvency and tend to clean a motor clowly. Valvoline MaxLife oil, in particular - seem to be highly recommended.
If you car is consuming excessive amount of oil (more than 1 quart per 1000 miles, in my book - Toyota says 1 quart every 500 miles) - need to find out where it is going. Most likely, it is being burned off - in many cases, without visible signs of blue smoke from the tail pipe. If you can, have someone observe the car when you accelerate from a stop and from a roll, deceleration events as well. There might be a hint of smoke there - that would pinpoint oil cunsumption.
Most likely areas are stuck piston rings on the earlier 1ZZ-FE engines (just Google it up) and/or leaking valve seals. Engine compression tests and leak down tests can help tell you what you have. Then you can decide how to proceed.
