engine shut off by itself, 99 Corolla CE with 120K+ - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2009, 01:27 PM   #1 (permalink)
I like old toyota cars
View hmpeng's Photo Gallery
This morning when I stop and wait to pick up a friend, suddenly the car just shut off. Can anyone give me any clue what's going on with the car. Everything function well, till this happeng. The car start right back, just kind of scary when the car just sit there and die. I also notice the clock were jumpie a little before it die.
Any help will be great or anyone with similar problem.
hmpeng is offline   Reply With Quote
Old 06-24-2009, 01:40 PM   #2 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Manual or auto? Did you havge a rough idle before it died? What RPM does it idle at once it's warmed up?
When it died were all the interior electronics still working, or did everything shut off with the motor?
Chris Corolla S is offline   Reply With Quote
Old 06-25-2009, 01:15 AM   #3 (permalink)
View BugDiddy's Photo Gallery
I would definitely clean the grounds from your battery, and possibly replace the negative cable.
BugDiddy is offline   Reply With Quote
Old 06-25-2009, 09:23 AM   #4 (permalink)
thanks for suggestion, will give it a try later today.
it's an auto transmission, car were run 20 minutes before sit there and waiting. Just out of sudden it just shut off by itself like I normally shut off the car with the key to turn to off position. Since the key still stay on position, all lights remain on.
also, battery were replaced last year, my first through is the alternator may need to replace or something. Since before the car shut off, I see the clock flick a little like not enough battery to support the light.
Old 08-15-2009, 11:30 PM   #5 (permalink)
View RickWood's Photo Gallery
I just had the same thing happen to me with a 2001 camry. Turned out to be the timing belt.
RickWood is offline   Reply With Quote
