If this keeps happening, then it might be a problem. From what you decribed- it sounds like either some bad gas, or in the process of filling - it temporarily clogged the sock filter on the fuel pump.
Double check that everything else looks OK - it is entirely possible that it was just a coincidence that the problems starting happening after you filled up the car, could be from something entirely unrelated to the refilling event. Check fluid levels, check the air filter, clean the MAF/IAT sensors, clean throttle body, pull the plugs and read them, look for missing or damaged vacuum hoses.
