Oil building up on the elecrode side is not a good sign - could be an oil control issue on that cylinder. That would cause a mis-fire, since the plug gets fouled by oil.
Do you notice any oil consumption on the car? If yes, how much oil does it go through. If you get a chance - do a compression test to see what the numbers look like. For the 1ZZ-FE values should run from 218PSI (max) to 145PSI (min) with no more than 15PSI difference between cylinders.
