OK - yeah, no condensation drain is sure sign of a clogged drain tube. Should be visible on the firewall, close to the exhaust manifold, if I remember correctly. Could always trace it back from the cooling unit inside the dash, behind the glovebox/center of the dash. The tube runs right out of the cooling unit, where the evaporator sits. Possible that mold/mildew have built up and clogged the tube, or there are even cases of algae clogged the tubes. I'll try and find a pic and post it up here.
