Don't believe you will need to pull the steering wheel - at least I didn't on my Matrix. Should be able to reach the wiper switch by just removing the lower steering column panel (something like 3 screws) and pressing a claw on the wiper switch to remove it. But I don't remember of the switch is on the side or under the spiral assembly on the 8th gen - if it is underneath it - chances are high that you have to pull the steering wheel off.
It is possible that the switch is still OK - just a bad connection (wiring issue) between the switch and the pump. Only way to know for sure is to test the connections on both sides. If you have a multimeter on hand you could buzz out the bottom of the switch itself.
