Engine swap??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2009, 04:56 AM   #1 (permalink)
~Veer~'s Avatar
View ~Veer~'s Photo Gallery
Engine swap???
what would be the best possible engine swap for a 2000 toyota corolla and also would it even be wise to do it with a A/T?
~Veer~ is offline   Reply With Quote
Old 07-11-2009, 05:06 AM   #2 (permalink)
on full afterburner
Gameroom cash: $1345597
What's your budget?
Old 07-11-2009, 05:24 AM   #3 (permalink)
~Veer~'s Avatar
haha no more then 2000$ i dunno if i can even get a good one for that much i dunno tho i was thinking maybe go to pick-a-part and just buy a used one with low kms
Old 01-27-2010, 11:09 PM   #4 (permalink)
~Veer~'s Avatar
Engine swap
Can i fit a 2JZ or a 2AZ-FE engine in a corolla the 2AZ-FE comes from the scion tC
Old 01-28-2010, 12:34 AM   #5 (permalink)
View dtrue's Photo Gallery
dam a 2JZ youd need more than $2000 for that. as far as the other engines go idk im just learning about toyotas lol
dtrue is offline   Reply With Quote
Old 01-28-2010, 09:39 AM   #6 (permalink)
DjiNN's Avatar
View DjiNN's Photo Gallery
You can put a 4AGE, 3SGTE, 3SGE, and 2ZZGE. I'm probably missing a couple but this topic has been asked about before.
EDIT :
Heres a list
http://trdforums.com/forum/showthread.php?t=15551
Subaru Impreza 2.5i Premium Satin White
DjiNN is offline   Reply With Quote
Old 01-28-2010, 09:51 AM   #7 (permalink)
~Veer~'s Avatar
In your opinion what would be the best swap... offering the most aftermarket support?
DjiNN regarding that link you provided will this one fit with out any problem and without much modifications?
2ZZGE VVTL-i - 2005
1.8 LITER DOHC INLINE-4
170 HP @ 7600 RPM
127 FT-LBS @ 4400 RPM
Also any non-toyota engines that you know that may fit?
Old 01-28-2010, 09:52 AM   #8 (permalink)
DjiNN's Avatar
http://www.phoenixtuning.com/toyota/swaps/mantis.html
Your answer ..
Old 01-28-2010, 10:06 AM   #9 (permalink)
~Veer~'s Avatar
Now im scared lol it said that it may need significant modifications i dunno d*ck all about engines i was hoping just take out the old engine and in with the new i dont wanna have to change the transmission
imma n00b
Only engine im willing to do major modifications for is a 2JZ...if it fits that is i havent really gotten many replies about that fitting or not :S
Old 01-28-2010, 02:54 PM   #10 (permalink)
on full afterburner
3S-GTE swap if your best bet if you're looking for power.
It's been done before.
IIRC, the total cost was about $10-$12K including parts and labour. A shop did the swap.
Guy was Canadian too.
Old 01-28-2010, 06:49 PM   #11 (permalink)
DjiNN's Avatar
well any engine will fit but all has to have modifications. More than anything it just depends on how deep your pockets are. 3SGTE would be the best bet for 98-02 corolla. Its turbo, our vehicles are light, and its not as exp as a 2JZGTE. only downside to a 3SGTE is the weight of the engine in our vehicles.
Old 01-28-2010, 06:59 PM   #12 (permalink)
~Veer~'s Avatar
what would be the best nissan engine that would fit like goot with not many mods, sorry im asking all these noob questions im just wondering.
i love toyota and all but i gotta love nissan engines
Old 01-28-2010, 10:38 PM   #13 (permalink)
Bdub215's Avatar
Gameroom cash: $317265
View Bdub215's Photo Gallery
The SR20 can be fit transverse and so can the KA24 but that requires custom everything.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 01-28-2010, 11:03 PM   #14 (permalink)
Toyota Tech in training!
View Downhillzze110's Photo Gallery
you would have a better and cheaper not to mention time retrofitting a 4A-G(Z)E 20 valve or a 2ZZ. you wont be able to keep your transmission for either without a VERY smart EMU. the 4A ECU is made for a A242E which you MIGHT be able to get to mesh with an A245E but a well built 4A (which youd need to justify the cost of the swap) will toast all but the toughest trannys. a 2ZZ will straight up ROAST anything but the Tiptronic or a 6 Speed. you'd be better off keeping the stock motor if you only want to spend 2000 as any 2ZZ in a junkyard probably has a fried oil pump and you wont be able to TOUCH a 4A 20V OR a well built 4A-GE for less than 2500 (if you want it remanufactured, which you will otherwise your playing russian roulette with your engine).
as for Nissan motors. you MIGHT be able to drop a SR20DE from a sentra SE-R or an older one from a 200SX. but you're still looking at 2000 for a reman engine alone. and a toyota transmission will need custom a bellhousing to bolt to a SR20. not to mention a custom EMU.
and as for your 2JZ... no, get it out of your head. a 2JZ is a physically LARGE engine (seen one out of car) and would not fit under the hood without EXTENSIVE modifications to the frame and Unibody. not to mention the 2JZ was ONLY designed for RWD, there is no Toyota transmission for the 2JZ that is NOT RWD. as for making your corolla RWD, you'd be better off buying a new car.
if your interested in keeping stock but want to have an automatic let me know. i can help you get a nice fun car for about 2000 to 3000 give or take. it wont be a straight line burner. if thats what your looking for then you have the wrong car. 8th gens make nice autocross cars but thats the extent for your average tuner that doesn't have ridiculous amounts of money.
before you ask a 'how do i...' question answer this for me. do you own a repair manual for it? have you searched the forum for a similar issue?
SEARCH THE FORUM BEFORE YOU POST!
Downhillzze110 is offline   Reply With Quote
Old 01-28-2010, 11:31 PM   #15 (permalink)
~Veer~'s Avatar
Well as PhatRoyale said in this post its going to be $10-$12k wouldnt it be smarter to keep the stock engine and get a custom turbo and what not made for it? like in a month or so i was going to buy an injen tech. SRI and stuff like that and i was going to get a body kit or possibly a lip kit from supershyguy but i also dont want a rice rocket i wanna be able to back up the looks of the car with stuff under the hood if your catching my drift...this car has like no power what-so ever you floor it and the tires barely spin -.- i was going to make a switch from a corolla to a supra and my dad was paying for everything too but its just to hard to get rid of this car i love it so much being my first and and everything...i also dont wanna spring for a civic i hate em so much everysingle tuner has one of those i wan an original car...if some civics can be tuned to be fast why cant corollas right? same engine size, and all basically same cars diff manufacturers....sorry i rambled on there...
