Rock Damage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2009, 07:28 PM   #1 (permalink)
View waygard33's Photo Gallery
Rock Damage
My daughter ran over a large rock on the highway in her 2000 Corolla automatic. I found she had smashed and punctured the transmission pan.
I ordered the pan and the gasket from the dealer and today when I removed the pan for replacement, I found another part, inside the pan was also smashed. It's too late to call the parts desk so looking for a little info here.
The part looks like a small reservoir, about 1/2" thick (was) and maybe 6 inches by 4 inches. Mounts with 3 bolts. What is this piece and any idea on cost?
Thanks in advance for any information.
Wayne in Oregon
waygard33 is offline   Reply With Quote
Old 07-11-2009, 08:24 PM   #2 (permalink)
View marty905's Photo Gallery
thats probably the filter, not expensive and easy to replace.
marty905 is offline   Reply With Quote
Old 07-11-2009, 09:14 PM   #3 (permalink)
NoLa Rolla
gaj1967's Avatar
View gaj1967's Photo Gallery
Does it look a little like this:
That's a filter/screen for a 4 speed. Since you never used the gasket yet you might be able to return the gasket and get a kit with the gasket and screen. Or buy just the screen. Cost should be around $20.
Gil
Did you search, here and on the internet, for your answer first? Chances are it was answered recently.
Re-read your post before submitting. Does it make sense to you?
Don't expect a response in two seconds. Nobody is getting paid for this.
gaj1967 is offline   Reply With Quote
Old 07-12-2009, 12:09 PM   #4 (permalink)
Marty & Gil...That's it. Thanks. Appreciate the info. Glad it's not anything expensive.
Wayne in Oregon
Old 07-13-2009, 10:40 AM   #5 (permalink)
Gearhead
Gameroom cash: $196215
Must have been some rock!
Once you pull the transaxle filter off - take a quick peek at the underlying valvebody for damaged/crushed sections, chunks of metal broken off, or cracks - valvebody is pretty expensive, but less expensive that a whole new transaxle. Hopefully, the damage was just isolated to the pan and filter.
Old 07-13-2009, 10:57 AM   #6 (permalink)
Yeah, leave it to my daughter to run right over it!
I pulled the screen/filter off and the underlying aluminum body looks great. I feel lucky as the screen (what the parts dealer called it - $38) was completelyl flat and mashed/wrapped around a bolt on the valve body which made it a little difficult to pull off once I removed the 3 bolts.
When I pick up the new filter and install, I will double check the body for cracks or other damage again. Hopefully all works well when I put it back together.
Thanks for your reply.
Wayne in Oregon
