Rear door - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-12-2009, 10:02 PM   #1 (permalink)
View Banana_Boat's Photo Gallery
Rear door
is it hard to replace a rear door of a corolla 98? What would i have to do?
Banana_Boat is offline   Reply With Quote
Old 07-13-2009, 10:38 AM   #2 (permalink)
Gearhead
Gameroom cash: $196215
You mean the whole door? If a straight swap, i.e., you have a complete door from a donor car - just remove your door (total of four bolts on the two inner hinges) - install the replacement door - reinstall the bolts, adjust as necessary and your done.
The hardest part is holding the door while your bolt or unbolt the assembly. Best to have help here - definitely much easier with two people. Need to have something to support the door from below - jack, wood blocks, etc. to help hold the weight of the door. Easier if it was a floor jack or scissor jack - so that you can move it up or down to line up the bolt holes.
