Should have the EVAP system "smoke" tested. Basically they fill the whole works with a tracer smoke, than use a probe to sniff out areas that the smoke is pouring out as they cycle the EVAP system. The evap codes have always been a PITA problem with the 8th gen Corollas.
Also, don't be tempted to top off the tank - on 8th gen Corollas, they are very susceptible to being easily overfilled. All that gasoline will eventually makes it way to the vapor canister and cause lots of headaches for you.
Smog laws vary from area to area - some places, you will automatically fail with any CEL. Some reset the ECM prior to being smogged, but in area that do an I/M or I/M 240 check - that will also automatically fail the test. Some areas will allow you to run the car on a chassis dynometer while monitoring emissions via a tailpipe sniffer instead, but not all areas will dothat.
