I have a 2002 corolla and the last days I've noticed some weird vibrations on the hood while waiting on the traffic and decided checking the engine/transmission mounts, and the one below the air intake is broken. Would you recommend changing the 4 engine/transmission mounts at the same time?
I'm also thinking about adjusting the suspension ( I forgot the name for the procedure with tires ) 'cause when I go beyond 100 kph I get some strong vibes ( is that related with the mounts? ).
And finally a few months ago I discovered that the radiator supports ( shown in the pictures below ) are kinda lose and the radiator having 2 fan coolers, in some moment will start shaking like crazy. I've been searching them on some online shops without luck. Has anybody here found/changed them?
