Did you have to send the old caliper back for a core charge or do you still have it. Sounds like the piston is jamming up on it, could be from contaminated brake fluid or dirt/dust making it way past the caliper seals.
Hopefully you flushed the old brake fluid while you have the caliper off - since you have to pull the brake line off. SS brake lines are a nice to have thing, but won't greatly improve braking with stock setup. It will help tale some "flex" out of the system (improve pedal feedback), but won't improve on line pressures to the caliper - those will remain unchanged, assuming you didn't have a problem previously.
