Xenon bulbs are generally used in HID systems. They cannot be wired straight into you existing system, as they are not able to power them up correctly. You'll need a ballast and igniter to get them to light up. Keep in mind, that HID bulbs also work differently than standard halogen - you might have an issue if you run them in a stock housing without taking the proper precautions. One is glare - especially to the other driver, the other is they made not pass inspection - some states would consider this modification "for off-road use only". In those cases, you cannot get the car registered for the street - just a warning.
