hi all,
I have a 1999 corolla with 85k miles and still with its original brakes.
recently when i inspected the brakes for the 1st time (i guess i might be blamed for that
), i realized that the drums can be easily slid off.
and when i put them back on, i can actually turned them a little bit until it's limited by the four bolts that are for the nuts to hold the wheel (the one on which tire is mounted, not the one that holds the drum) on.
imagine that since the diameter of the drum's four holes are slightly bigger than those four long bolts, there will be some "free play" if the drum is not secured steadily on the wheel (this is not the wheel on which the tire is mounted, it's the inner one i'm talking about here).
the question is, is that a problem with my drum or the problem with my inner wheel that the drum is put on? how can i tell?
surprisingly, i think this issue actually started back in year 2002. so that's 7 years ago!!!
i remembered since that time, i sometimes would hear some kind of noise like collision of two pieces of metals from the rear of the car when i apply the brakes.
until after i inspected the brakes recently and got to understand the structures. i suspected that the sound is basically the drum hitting the bolts.
i verified that by paying attention to under what conditions that noise will come when i apply the brakes.
and that is if i've braked when the car was going forward, then i let the car go reverse and the first brake will have the sound; similarly, after i stopped when going reverse, and the first brake when i go forward, the sound will come.
this is because when my car is going forward, and i apply brakes, the shoes will stop the drum first, but since the drum is loose on the inner wheel, the drum won't be able to hold the wheel until the bolts are touching the front side of the holes on the brake. and if i drive in the same direction again, since the bolts are already touching the front side of those holes on the drum, there won't be the metal collision noise. but if the car goes in opposite direction, and brake is apply, then the bolts would have to hit on the back side of the holes on the drums.
this is a little lengthy, but i think you guys already got the idea after reading maybe 30% of this part.
so, can anyone explain me how the drum is supposed to be secured on the inner wheel, and any suggestions for my issue? especially how to examine whether it's the inner wheel's problem or the drum's prolbem
thanks very much in advance!
