Hi,
I am a new poster here so please forgive me if this has already been covered but I tried searching and couldn't find much concrete information about it.
I have a 2001 Corolla and the low-beam bulb has burnt out on the driver side.
I was looking at just replacing the bulb myself as it would be much cheaper then taking it to a mechanic, i am a complete noob at it but I found some online articles that make it seem fairly easy so I will give it a shot.
Now I am trying to decide if I should just buy another halogen bulb like
this one OR I found on eBay several interesting alternatives.
The first one I found is called the "
HiLite Superlite XE" I did a little bit of research and it looks like these are not real xenon or HID lights, they very similar to xenon lights so it will give me a much brighter output then standard halogen lights. What's interesting is it claims I don't need to modify anything at all and I can just literally plug these bulbs in as a replacement and it will work properly with no problems, for this particular model it even saids it uses the exact same wattage as the halogen bulbs.
Is this true? Do I really just plug in these bulbs like they are halogen ones and it is good to go? Anything wrong with doing that or anything I should be aware of? It just seems a little too good to be true.
The second ones I found is "
HiPro Power", which is very similar to the first one, it saids I just plug it in like a regular light bulb, but it does say it will uses around 65w vs the 50w for a stock halogen bulb, that has me a little concerned as I don't really want to break anything by doing this.
What should I do? I want something brighter then the stock bulbs, it is just not bright enough for me when driving at night, I can barely even tell the headlights are on and the cover is as clean as it can be.
PS: I am located in Canada so DRL are a MUST, will this somehow affect my DRL?
Thank you very much in advance!!!
