Originally Posted by Steve40th
I just greased the pulley, took the bearing covers off and regreased it.
The tensioner is new, 70 bucks, from Toyota, as you dont need the whole assembly.
Do you need to grease the bushing on the part of the tensioner which bolts to the assembly?
yes that is where my noise was coming from. there were, in my case, metal sleeves inside fiber bushings. they had dried out and the rubbing of the metal against the fiber sleeve caused the noise. the pulley and bearing were actually in good shape on mine at 60,000 miles. this is on the tensioner which looks kinda like a shock absorber.
i might add also that taking this off may not require full removal of the idler assembly. try this (i have not yet)
- release belt from tensioner to free up tensioner
- there is a bolt on the bottom of the spring tensioner (shock looking thing). it is accessable from the back side. remove it.
- remove the nut at the top.
- swing the tensioner up and then pull off of the stud.
this will leave the main bracket and pulley still on the engine but you will have the spring assem in your hand. clean and regrease the bushed ends.
hope this helps!
mike
