agree with you on the additives! im not at the brake fluid additive yet!
got the fluid/filter change completed yesterday. fluid came out dark tho not black. didnt have the atf "stink" like the fresh fluid. pan was clean of debris. only had a thin film of gray sludge or mud as i like to call it. had 2 magnets. a small amount of sludge around them. metal particles were so small as to be imperceptable. so overall it was a very promising sign.
i could see some matter in the filter screen tho it was very small particles. the screen was not covered completely so i dont think the filter was causing any blockage. it looked pretty good actually.
replaced the cork gasket with a rubber one from the auto zone kit, tightened all down to 48inch pounds.
added syth blend dexron III fluid.
also did a brief flush by disconnecting the output line from the cooler.
disconnected the line and ran the motor for about 15-20 seconds maybe at most. dont know how much good it did, but hopefully it flushed some of the old fluid out from the converter and cooler.
topped it all off and added about a half pint of sea foam.
drove it today. it seemed not to help much with the bump. but i feel better that it has at least some fresh fluid.
it was a good note you made that the sea foam will take time to work. if it is sticking parts i can see that it will take a bit for them to work themselves loose. if it starts to improve i may do another fluid change and additive.
if i left out anything let me know.
the saga continues!
thanks for your very much valued input!
