LED tail lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2009, 11:35 PM   #1 (permalink)
View AJW6's Photo Gallery
LED tail lights
I can't find any LED tail lights online for the 8th gen (only 03+). I did find LED bulbs that fit in OEM housing though. I was wondering if anyone has tried these in their brake lights or turn signals or anything. I wasn't sure if it would look tacky or actually good. If anyone has tried these or anything like them, let me know please!
AJW6 is offline   Reply With Quote
Old 08-12-2009, 12:38 AM   #2 (permalink)
Gameroom cash: $120900
View Milky's Photo Gallery
i have used led bulbs in past cars with good results. the only down side is your turn signals will blink faster. as for the brake lights you will have no problem.
Milky is offline   Reply With Quote
Old 08-13-2009, 02:10 AM   #3 (permalink)
Raging Raven
View TenZen's Photo Gallery
The last LED bulbs i bought for it were the brake bulbs they didnt work. They lit up, but wouldn't get brighter when you stepped on the brake, so i never went back to LED's since then. Then again, theres the chance that those bulbs were just crap.
2005 Dodge Neon SRT-4
Originally Posted by FinalGear View Post
gosh...those honda guys....as soon as they put the intake in their Civics...it goes faster than any Mustang, Evo, and Sti....
TenZen is offline   Reply With Quote
Old 08-13-2009, 10:49 AM   #4 (permalink)
excellent, thanks for the heads up. How did they look, though? Did they actually look like legit, exotic led tails? or could you tell that someone threw a pair of $5 leds in stock housing?
Old 08-14-2009, 12:39 AM   #5 (permalink)
they will look like someone put leds in a stock housing. the only real way to make a true led tail light is to take it apart and put in a led circut board then wire it all up. but its usually a big hassle for most people.
Old 08-14-2009, 09:25 PM   #6 (permalink)
Raging Raven
what milky said.
Old 08-24-2009, 11:19 PM   #7 (permalink)
Constant Tinkerer
downsb's Avatar
View downsb's Photo Gallery
I've been swappin everything in my car (slowly) for LED lights. I agree that the LED's for brake lights aren't great ideas...I put mine in there and anyone behind me complains how they can't see them well...if you're gonna get LED's make sure to get the ebay termed 'SMD' type (I didn't get SMD's for my brake lights and that's why you can't see them). Those are MUCH brighter than the traditional LED bulbs and work better. The blinking can be fixed if you do 1 of 2 things:
1) get a relay that slows the blinking down (ebay it)
2) put a resistor in the circuit (the LEDs don't resist the current as much as traditional bulbs so the car thinks the bulb is out, which is why it blinks faster)
The relay will be easier bcuz it's plug 'n play most of the time...but the resistor will be cheaper by far.
2001 Corolla LE- Secret Weapon SRI; Skunk 2 lowering coilovers; KYB GR-2 struts; Megan Racing sway bar; AutoZ Concepts indiglo dash; JDM Carbon Fiber tail lights; K6 LED side mirrors; JDM drift steering wheel; Walbro high-flow pump
downsb is offline   Reply With Quote
Old 08-25-2009, 08:44 AM   #8 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
Relay all the way, forget the resistor.
SMD (surface-mounted) LEDs are the newer types which are brighter, but I think it matters more how they are placed on the bulb. I look for units with more LEDs and pointed in all directions. "Barrel" bulbs (so named for their shape, the kind with one round circuit board on top, and another 5 or 6 strips down its sides with 3 LEDs each) seem to work best.
This is what I am running now:
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
