Need help with my rear wheel assembly - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2009, 07:13 PM   #1 (permalink)
The Mada
MadaGnik's Avatar
View MadaGnik's Photo Gallery
After taking my rear wheels off over the years my lug nuts began to strip and I would always tell myself- "next time ill get some new lug nuts". Well, from my stupidity the lugs themselves began to strip and finally last night when my friend and I were adjusting my rear brakes, one snapped off. I am going to the junkyard this weekend, everything is half off. What all should I pick up? Im asking because I don't want to replace more than I have to.
Thanks in advance.
PS: Yes, i know one nut is on backwards, and the others aren't the right ones
MadaGnik is offline   Reply With Quote
Old 08-13-2009, 08:56 PM   #2 (permalink)
00 rolla VE
View huangxin's Photo Gallery
brand new lug from o'reilly auto parts is less than 2 bucks each... why bother getting used?
[IMG]file:///C:/DOCUME%7E1/HP_Owner/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
05 engine under a 00 hood! Another 8th gen is back on the road!
huangxin is offline   Reply With Quote
Old 08-13-2009, 11:34 PM   #3 (permalink)
The Mada
MadaGnik's Avatar
What im saying is that the bolt that the lug nuts screw on to snapped in half.
Old 08-13-2009, 11:46 PM   #4 (permalink)
00 rolla VE
i know
the lug ("the bolt the lug nuts screw on to") is pressed into your rear wheel hub. you can press it out and install a new one into the hub. the replacement lug from o'reilly is 1 buck something + tax.
Old 08-13-2009, 11:49 PM   #5 (permalink)
Banned
View zuzu_'s Photo Gallery
I think you need a replacement hub.
zuzu_ is offline   Reply With Quote
Old 08-14-2009, 12:24 AM   #6 (permalink)
ロンリードライバー
Gameroom cash: $224935
View all2baka's Photo Gallery
The wheel stud itself can be replaced. Just hammer it out and replace with a new one. They're only like $2 even from the dealer. I've replaced 2 already that snapped in half before, one in the rear and the other in the front.
all2baka is offline   Reply With Quote
Old 08-14-2009, 12:20 PM   #7 (permalink)
randini667's Avatar
View randini667's Photo Gallery
Please don't replace the hub assembly.
As mentioned, you need to go to the parts store and get a lug stud, maybe get 2 in case it happens on the other side. couple dollars a piece, i've done this before.
Then you have to knock out the old lug/stud with a chisel and hammer, or I used a clamp. Then put the new one in and using a nut, tighten the lug down so that it draws/presses into place, remove the nut and you're back where you started.
randini667 is offline   Reply With Quote
Old 08-14-2009, 01:26 PM   #8 (permalink)
The Mada
MadaGnik's Avatar
Wow, thanks a lot. Saved me a lot of money and work. I'm gonna look into doing it this weekend.
