98 1zzfe timing problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-15-2009, 10:00 PM   #1 (permalink)
Fergifruitchew's Avatar
View Fergifruitchew's Photo Gallery
im still trying to time the damn thing, dont think that i have not looked around in this forum and elsewhere to find the timing marks because i have and this is what i have found:
1:
http://www.therussian.net/random_crap/timingChain.pdf
2:
Need help after a rebuild
3:
http://www.corolland.com/forums/inde...howtopic=20751
on the PDF, it seems so easy, just mark the intake cam IN. right across the Exhaust cam EX. with the crank set at 0 on the timing marks...i get cranks but they are rough and when i let the key go it seems like i fires once and dies. Any ideas
Fergifruitchew is offline   Reply With Quote
Old 08-16-2009, 08:17 PM   #2 (permalink)
the main problem is, i can have the crank set on "0" but the two cams EX and IN NEVER line up, not even after a 360 degree turn on the crank!, why dont they ever line up, its frustrating
Old 08-17-2009, 01:04 PM   #3 (permalink)
i found out what it all was, the crank sensor plate, when i took the engine apart, the original got damaged so i replaced it, and the replacements #1 piston fire order was in a different area, so it was firing wrong the whole time, so i got the original one and it works perfect now, starts right up and runs fine.burns lots of blue tho, but it will soon go away once the engine gets warm and highway driven for a while. I need a new clutch first.
thanks for trying to help
