Shocks and struts? Upgrade? - 01 Corolla CE? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2009, 12:35 PM   #1 (permalink)
View morkys's Photo Gallery
I have an 01 Corolla CE and the shocks in the rear are not working very well. Either that, or some links/bushings are in need of service replacement, since there is knocking in the passenger rear over ripple bumps at low speed. Regardless, I want to replace my struts at some point to improve handling. Not going racing, just want better handling, a step up from stock, nothing extreme. My 01 Corolla CE has 120,000 KM's on it (75K miles).
What are the options for replacing my shocks and struts? I understand there are aftermarket replacements that are an upgrade from stock. Are there a few options? Similar dampening? Harder? I'd like close to stock.
Wouldn't mind also looking at lowering the car slightly, say 1/2" to 1 inch or so...whatever...not too much. Any springs with small lowering amount out there?
EDIT - In addition, below I've refined my post to include questions about which stabilizer/sway-bars and/or strut tower braces are a good mod, and what order to do all these mods in.
thanks,
morkys is offline   Reply With Quote
Old 08-19-2009, 01:17 AM   #2 (permalink)
Constant Tinkerer
downsb's Avatar
View downsb's Photo Gallery
I've got a set of KYB GR-2's with Skunk 2 adjustable coilovers and they are noticeably stiffer.
If you want something closer to factory there are several options at local parts stores (something like Monroe).
IMO if you've got to replace anyway, why not upgrade? Not to mention if you're wanting to lower the car a little it's not advised to go with something that'll be close to stock stiffness...I tried stock struts with my skunk 2's and it made going over bumps VERY scary...the car bottomed out on the top of the strut mount nearly EVERY time REGARDLESS of the size of the dip/bump/hole and gave for a very strange ride which made handling awful. So if you're gonna lower the car get stiffer suspension-although it may be a few extra bucks and give the ride a bit of harshness in the long run you'll be happy you did it.
When replacing the rear struts keep in mind that unlike front struts on this car the rears have the brake line going THROUGH the metal flange holding the line in place and must be taken apart (fronts the line is 'clamped' in place by nuts but can be easily loosened and removed without taking the brake line off).
A lot of great strut assemblies are out there; Koni Yellow, Tokiko, and KYB are some of the performance related brands most used and that usually says a lot about the kind of reliability and dependability you'll get out of these. I've done research and from what I see KYB is the original manufacturer for this part (although the GR-2's are aftermarket upgrades).
For coil-overs or lowering the car decide if you want to be able to control the height or if you'd prefer to have it set permanently at a certain height. You can get shocks that are just shortened or ones that have a center tube that has interlocking nuts which allow you to raise and lower the vehicle if you choose to.
Another thing to think about with struts is that you can get ones with adjustable stiffness (they'll have an allen tool or something similar that you can adjust the stiffness with by turning a bolt on the top of the strut cartridge). The stiffer the ride, the better the handling due to less body-roll.
Whatever you get it's smart to get something that comes with a warranty. Although 9 times out of 10 you won't need it there have been struts that go bad quickly or are bad to begin with.
One last thing: When installing the coil-over on a strut there's a metal seat that the original boot sat on and most struts have this...in my case the coil-over wouldn't fit over it, but wouldn't sit on it completely...I just took a hammer to it and broke them off.
2001 Corolla LE- Secret Weapon SRI; Skunk 2 lowering coilovers; KYB GR-2 struts; Megan Racing sway bar; AutoZ Concepts indiglo dash; JDM Carbon Fiber tail lights; K6 LED side mirrors; JDM drift steering wheel; Walbro high-flow pump
downsb is offline   Reply With Quote
Old 08-19-2009, 03:15 PM   #3 (permalink)
Interesting. Thanks for the feedback. So it seems the KYB GR-2 struts are somewhat fairly popular.
How much did you lower your car? I'd like to lower mine a small amount. Like 5/8" or 1 inch or so. Is that small amount even possible?
Old 08-19-2009, 05:21 PM   #4 (permalink)
Constant Tinkerer
downsb's Avatar
If you get a set of adjustable coilovers lowering can be done in nearly any increment (up to the length they support). Some coilovers will say they will lower your vehicle to a certain amount (and they will) but you'll have to have struts that are about as stiff as straight metal bars. I've got mine lowered about 1"; the skunk 2's I have are good to about 2.5"-3" but the GR-2's aren't good struts for anything lower than 1.5".
If I could go back and do it again I'd go with Tokico probably. Koni Yellow is pretty expensive, and KYB's are good, but I'd like to have the ability to lower the vehicle more without the likely possibility of tearing the struts up.
Tein lowering coilovers for 1.2"
This is the set I have (ebayed for ~$210 new)
Non-adjustable Skunk 2's
This is another set of adjustable coilovers
It's not very easy to find 1" or less on a set of non-adjustable coilovers. The first link is the closest I've found. If you're willing to drop ~1.5-2" you can find a set for about $100 new...but like I said, unless you've got a stiff set of struts I wouldn't recommend that far of a drop.
Old 08-19-2009, 05:31 PM   #5 (permalink)
on full afterburner
Gameroom cash: $1345597
Not from what I have seen, no.
Minimum is around 1.5".
Old 08-19-2009, 08:07 PM   #6 (permalink)
View AJW6's Photo Gallery
Those aren't real coilovers are they? It would seem strange that a coilover kit would cost less than a KYB/Tien set up.
AJW6 is offline   Reply With Quote
Old 08-19-2009, 08:17 PM   #7 (permalink)
Well, I suppose 1.2" to 1.5" is doable. No more than that though. I would like a performance improvement, but I'm not looking to go too far with that.
Are Tokico stiffer than KYB's? The same? Similar to stock? I'd prefer stiffer but not too stiff.
Old 08-19-2009, 08:19 PM   #8 (permalink)
on full afterburner
Tokico's are stiffer than KYBs. But if you're only dropping that little then KYB's will do just fine.
Old 08-19-2009, 09:01 PM   #9 (permalink)
1.2" drop is fine with KYB's then. A small drop with stiffer than stock shocks. Sounds about right. Now I just need those Sport Edition D5 alloys. Cash strapped this summer.
Old 03-11-2010, 03:51 PM   #10 (permalink)
A review of sorts.
So how do KYB GR-2's and Tokico shocks compare to one another? Is it simply a matter of the Tokico shocks being stiffer than the KYB's? Is there no other difference?
I haven't decided whether I am going to lower the car or not. I don't have much 'extra' cash around and so I'm deciding what it's best for me to invest in. I am getting new rims this year, and maybe a few other things. I'm not sure I want to lower the car at this point. I guess I will check out the lowering spring options and decide once I've priced it out.
Also, what other mods are there for these cars in the stability/anti-roll department? Strut bar? Stabilizer bar upgrades?
thanks,
Old 03-11-2010, 05:35 PM   #11 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
Hotckiss makes a great sway bar set for the 8th gen.
Ultra racing also makes a nice selection of chassis bars.
SCCA First Place 10/25/09. NST
Crowbar911 is offline   Reply With Quote
Old 03-11-2010, 10:28 PM   #12 (permalink)
on full afterburner
A review of sorts.
thanks,
You pretty much answered your own questions.
Old 03-12-2010, 06:32 PM   #13 (permalink)
Constant Tinkerer
downsb's Avatar
I bought a Megan Racing sway bar which works really well for about $25 off E-bay. (I've got another stock 01 Rolla LE so I can test and compare to stock using this 'control' vehicle).
The Following User Says Thank You to downsb For This Useful Post:
morkys (03-21-2010)
Old 03-13-2010, 09:14 AM   #14 (permalink)
A comparison would be neat.
Old 03-13-2010, 02:07 PM   #15 (permalink)
LOVE the Mazda's
rx7rocket2010's Avatar
View rx7rocket2010's Photo Gallery
Talking
I have tokico hp series shocks abou 300 for 4. And I got ground control coilovers made by eibach another 400 but really hard to find now especially now I've done anything from 1/2 inch drop on 17s to 3 inch on 15s and I don't rub bounce ar scrape just my 2 cents
rx7rocket2010 is offline   Reply With Quote
