tail lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2009, 12:07 AM   #1 (permalink)
View kongmen's Photo Gallery
tail lights
Just bought 2000 priszm and tail lights and dash lights won't work all others work sig.brake ect. every time I put a fuse in and turn on lights it blows right away. Any ideas? Thanks.
1991 corolla sedan 1.6 auto. 188k.
2007 camry v6 xle 20k.
kongmen is offline   Reply With Quote
Old 08-17-2009, 01:38 PM   #2 (permalink)
Toyota Tech in training!
View Downhillzze110's Photo Gallery
start hunting for shorts...
bring Tylenol, a Digital Multimeter, a lot of patience, wire, wire strippers, shrink wrap, and wiring diagrams.
you're in for a LONG day friend.
before you ask a 'how do i...' question answer this for me. do you own a repair manual for it? have you searched the forum for a similar issue?
SEARCH THE FORUM BEFORE YOU POST!
Downhillzze110 is offline   Reply With Quote
Old 08-17-2009, 02:42 PM   #3 (permalink)
I did some searching and found a common problem with the drl circuit board behind the glove box. I checked the board and nothing is burnt like in pics shown on some posts here. I'm going to try the tail light fuse while I have the drl board out and see if it blows if it doesn't then I will at least know it has something to do with the drl board.
Old 08-17-2009, 05:44 PM   #4 (permalink)
Well, of course the fuse didn't blow with the drl board out because no power is supplied to the system without it I cut the red/blue wire at pin 23 on the dlr module then tried with new fuse it still blew. I tore apart the drivers side interior and got to the relays behind the fuse box 2 black and 1 gray (largest one) I took them out one at a time while trying a new fuse and turning on the lights each time the 15 amp tail light fuse blew until all were out and it still blew with all relays out. Any suggestions?
Old 08-17-2009, 05:55 PM   #5 (permalink)
attack of the reposts (a thousand apologies)
Old 08-17-2009, 06:08 PM   #6 (permalink)
Raging Raven
View TenZen's Photo Gallery
Short somewhere. Check the wires under the door panel on the drives side (the panel right under where the driver's side door goes when its close since one of those wires go to the tail lights). Dont know about the other one.
2005 Dodge Neon SRT-4
Originally Posted by FinalGear View Post
gosh...those honda guys....as soon as they put the intake in their Civics...it goes faster than any Mustang, Evo, and Sti....
TenZen is offline   Reply With Quote
Old 08-17-2009, 06:22 PM   #7 (permalink)
Thanks for the lead I'll check it out.
Old 08-17-2009, 10:07 PM   #8 (permalink)
Well, Ive' checked a few more things like the driver's side door jam (under the plastic) wires look good there, all tail light bulbs and sockets all looks good no melted contacts or filiments. I have no way of knowing if the previous owner had an aftermarket radio in it or not. I think the next thing on the list is to pull the radio and check all wires there also the a/c don't work so I'm wondering if there might be some wires behind the radio that is affecting the a/c and the tail lights/dash lights. Wish me luck. I will post if I find the problem.
Old 08-19-2009, 05:20 PM   #9 (permalink)
I think I'm going to have to take it to a shop. I've had the whole dash apart all tail lights out and the radio out also had the instrument cluster out unplugged all connectors fuse still blows as soon as I turn on the head lights. The only thing I can think of now is the light stalk it's self. Anyone ever have an issue with the stalk? How difficult is it to take apart?
Old 08-20-2009, 05:17 PM   #10 (permalink)
Has anyone taken the light switch off before?
Old 08-27-2009, 03:39 AM   #11 (permalink)
Took it to a shop. There was a short in the left fender.
