Need advice on how to fix side mirror - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2009, 08:40 PM   #1 (permalink)
View ToyotaTime2002's Photo Gallery
Hello. This is my first time posting so please bear with me. I have a 2002 Toyota Corolla. My passenger side mirror is cracked. It is not a power mirror. I was wondering if I could just replace only the mirror or do I have to replace the entire unit. Thanks in advance for you input.
ToyotaTime2002 is offline   Reply With Quote
Old 08-18-2009, 08:54 PM   #2 (permalink)
Toyota Tech in training!
View Downhillzze110's Photo Gallery
you have to replace the whole unit. i had the same thing happen to me... twice. (driver side albeit). toyota genuin part is like 90 something... my suggestion... how much do you REALLY need that mirror? you may want to also check part stores. you MAY be able to get it cheaper... i'm not sure tho...
before you ask a 'how do i...' question answer this for me. do you own a repair manual for it? have you searched the forum for a similar issue?
SEARCH THE FORUM BEFORE YOU POST!
Downhillzze110 is offline   Reply With Quote
Old 08-18-2009, 09:24 PM   #3 (permalink)
View liensalebuyer's Photo Gallery
if it's just the mirror and not the housing, I think you can pry the mirror off and go to a windshield shop, there are aftermarkets for the actually mirror only, much cheaper than buying the whole thing.
liensalebuyer is offline   Reply With Quote
Old 08-18-2009, 09:27 PM   #4 (permalink)
Banned
View zuzu_'s Photo Gallery
Someone broke the motor in my passenger's side power mirror (probably by poking at it as if it were a manual mirror), and same problem: replacement was about $90. Plus, either I'd have to pay to have it painted to color match the driver's side (same as the body paint), or buy two and keep them black (unpainted), which matches the door trim just fine.
My solution was to buy a pair of black "M3" power mirrors on eBay for $40 total. I had to put more effort into their installation: buy screws that weren't included, use GE Silicone II to make the seams waterproof that otherwise would leak rain water inside the door, etc. So final cost, minus my time and effort, was maybe $50. They look nice. They even have amber LED turn signal lights that can be wired up. The motor controls are backwards though; there was no other 3-wire combination that was even close except to have up-down swapped and left-right swapped. Also, the mirrors are slightly smaller than OEM, which obviously reduces visibility.
Since you don't have power mirrors, you don't have to worry about the 3-wire issue. The manual mirrors are even less expensive too; like $30. Also, there's way way more style options available online in general for aftermarket manual mirrors.
zuzu_ is offline   Reply With Quote
Old 08-18-2009, 09:29 PM   #5 (permalink)
View The ///Man's Photo Gallery
don't get it cut, it will look like crap and regular mirror glass is too thick. Find a glass shop that caries redicuts http://www.burcoinc.com/ and it's an easy fix. Passenger side is also convex.
The ///Man is offline   Reply With Quote
Old 08-18-2009, 09:34 PM   #6 (permalink)
To be honest with you I wouldn't even bother repairing it if I didn't have to. the crack is not even obstructing my view. Unfortunately, in order to pass Maryland inspection it has to be fixed.
Old 08-18-2009, 09:39 PM   #7 (permalink)
My one question is...if you can not only replace the glass why does Toyota and even places like Pepboys sell replacement side mirrors for my vehicle.
Old 08-18-2009, 09:48 PM   #8 (permalink)
your question makes no sense? You can replace just the glass.
Old 08-18-2009, 09:51 PM   #9 (permalink)
the power mirrors you CAN buy replacement glass for. but for the manual mirrors you can't. trust me. i've had to replace mine twice. once was cuz some old guy hit it (he owed up to it) the other was vandalism.
Old 08-18-2009, 09:52 PM   #10 (permalink)
I own a glass shop, you can
I looked it up for you, Redi cut #3626, should cost the shop around $15
Old 08-18-2009, 09:53 PM   #11 (permalink)
That's what I was hoping to do but it seems like all the above posts are saying that I can not just switch out the glass. I realize there is a post mentioning Redi Cuts but aside from that it seems it can only be replaced as a unit.
Old 08-18-2009, 10:02 PM   #12 (permalink)
Thanks ///Man. So if I decided to go this route would they also be able to install it or is it just a matter of using some type of industrial adhesive to keep it in place.
Old 08-18-2009, 10:04 PM   #13 (permalink)
Also, I may have jumped the gun and preordered a replacement mirror from Pepboys. Should I not even go this route.
Old 08-18-2009, 10:09 PM   #14 (permalink)
if you get a burco redicut, they come with a double stick adhesive with the packaging along with a free replacement warranty. Just break out the old glass, clean both surfaces very will with some alcohol or acetone or whatever and stick it in place. I'm sure the shop can do it, but you might be able to save a buck or two DIY
Old 08-18-2009, 10:13 PM   #15 (permalink)
Thanks again ///Man. So do you think I should abandon the idea of replacing the mirror with a part that I preordered from Pepboys?
