Hi all
So I have various problems with my CE:
has 144,000 miles
The engine:
It takes several cranks in order for the car to start up. It's worse when the car is cold.
Transmission:
When backing out of my driveway, after shifting into drive from reverse, the car is
extremely sluggish. You could have your foot planted on the accelerator and you will only move at <5mph for at least 7+ seconds. Then all of a sudden it kicks in. I checked the tranny fluid and it's a bit discolored. A brownish color but still smells like petroleum.
Interior:
The driver's side door handle does not work. The handle itself is not broken but you can't open the door the from the inside. It only works from the outside. I saw this thread: (
inside handle) but wasn't sure if it was just the inside door handle as it is still intact.
The driver's side window will go down but when you try to bring it up, it takes ages. It will get jammed and you have to wait a few seconds or up to 30-45 seconds and slowly inch it back up. Would this just be the regulator? Or the motor as well? If anyone can provide a DIY for removing the door panel, that'd be great.
Thanks.
