98 LE Cruise Con issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2009, 11:03 AM   #1 (permalink)
View lawrid's Photo Gallery
My cruise control stopped working the other day. When I click the on/off switch, I can hear a clicking sound from the brain box under the glove compartment, but the cruise light doesn't come on in the instrument panel any longer.
Any ideas on diagnosing this? Would it be a simple matter of replacing the brain box?
Thanks.
lawrid is offline   Reply With Quote
Old 08-23-2009, 03:03 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
Check the GAUGE and ECU-IG fuse, both 10A behind the little drawer to the wheel's left. Speedo works? And the CRUISE bulb in the cluster?
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 08-23-2009, 06:56 PM   #3 (permalink)
Yes, the speedo and the bulb are fine, so it may be just the fuse. I will check it out and let you know.
Old 08-23-2009, 07:26 PM   #4 (permalink)
I pulled both of the fuses you suggested. Both looked good but once I replaced them, the cruise started working again. Perhaps just vibrated loose after 173,000 miles.
Thanks for the help.
