Rear Spring Diameter? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2009, 09:33 AM   #1 (permalink)
View bybliz's Photo Gallery
Question Rear Spring Diameter?
Hey guys, I'm too lazy to go out and jack my car up to measure right now, just wondering if anyone knows off the top of their heads.
I have a 2002 Corolla lowered on Tokico Blues and Tein S.Tech Springs, My problem right now is that my rear end is too low and my tire is rubbing the wheel well everytime i go over a steep enough bump/drop. I've already removed as much weight as possible from the back including my subs and its still rubbing. I've also tried adding more negative camber using bolts but thats not helping either.
My next option is to raise the rear maybe an inch or so using coil spring spacers. Problem is i need to know what the diameter of my rear springs are to order the correct ones.
Does anyone know what the outer spring diameter is for the rear springs?
bybliz is offline   Reply With Quote
