Originally Posted by Mistri2001
01 model has only map lights in the rearveiw mirror. 04 rear view mirror also has auto dimming and compass feature in it.
Can I install 04 rear view mirror in 01 corolla.
What are the input wires in the 04 mirror harness. In 01 corolla there are only 2 wires going in and they are supposed to be for the map light only.
Looking at my info at hand the 04 mirror connects with a 7-pin connector (90980-11794). Pin 6 is ground, pin 1 is battery power (wire to your dome light's power source, it feeds your map light), and pin 7 is ignition-on power feeding your electrochromic mirror. Not sure if the other 4 positions are used.
I wonder if this can be made to work on a 98-00 with roof mounted mirror instead of windshield mounted.
Mounting 04 mirror on a 01 should not be too bad. A clip is glued to the windshield. See if that fits. The worse that can happen is that you will need to pull that off (careful!) and with a rear mirror repair kit, glue your 04 mirror on.
