Rebuilders, what rings are you using, NPR ok? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2009, 10:21 PM   #1 (permalink)
randini667's Avatar
View randini667's Photo Gallery
Hello,
I'm close to re-ringing my 2001 1ZZFE Prizm. Just wanted to see what rings other people are using or recommending? (and where to buy them).
Nippons seem readily available at the usual places, any good?
Thanks, Randy
randini667 is offline   Reply With Quote
Old 08-27-2009, 10:42 PM   #2 (permalink)
Fergifruitchew's Avatar
View Fergifruitchew's Photo Gallery
i would suggest getting OEM whatever brand they could be i dont know.
Fergifruitchew is offline   Reply With Quote
Old 08-28-2009, 10:02 AM   #3 (permalink)
View dorman68's Photo Gallery
Stick with oe.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 08-28-2009, 10:05 AM   #4 (permalink)
Gameroom cash: $120900
View Milky's Photo Gallery
total seal is a great brand, but at the price. gapless, less than 2% leak down. but about 200 for the set of rings... ouch!
Milky is online now   Reply With Quote
Old 08-28-2009, 05:54 PM   #5 (permalink)
View JeffG's Photo Gallery
Ummm but many are replacing oem rings because they were crap, stuck and led to the burning issue to begin with... Why would one go with oem a second time? Perhaps Toyota corrected them, or perhaps early 8th gens received a bad batch?
JeffG is offline   Reply With Quote
Old 08-28-2009, 10:36 PM   #6 (permalink)
View CJCride's Photo Gallery
Canada
Originally Posted by randini667 View Post
Hello,
Thanks, Randy
Just curious, someone mentioned that there are tiny holes in 8th gen. pistons that carbon up easily.
When you get one of them out could you clarify if the holes are in the crown? the ring grooves or the skirt.
Much appreciated.
CJCride is offline   Reply With Quote
Old 08-28-2009, 10:46 PM   #7 (permalink)
View Steve40th's Photo Gallery
Much appreciated.
Pics would be nice too.
Steve40th is offline   Reply With Quote
Old 08-29-2009, 12:06 AM   #8 (permalink)
Much appreciated.
its in side the ring groves for the bottom ring ( the oil controll ring) this is why they have the problem of burning up, it causes the rings to stick and not properly wear/controll oil on the cylinder walls, leading to buring the oil.
Old 08-29-2009, 12:37 AM   #9 (permalink)
Canada
Thanks man, I'll be seafoaming the engine shortly and wanted to know exactly where to target. I'm going to squirt about 2 ozs into each spark plug hole on a warm [not hot] engine, let it soak about 8 hours replace the plugs with a cheaper new set of Bosch Platinums burn off the crap. Finally I'll pull the Platiinums and reinstall the Iridiums. What do you think?
Old 08-29-2009, 12:56 AM   #10 (permalink)
not bad idea. i dont know if seafoam wil break it all lose. i would also try cranking the engine over by hand with the plugs out. crank it over slowly so you just a couple of revolutions to get the seafoam down all the way to the rings.
i have heard of a similar process but they used marvel mystery oil. it was on an old farm tractor that had not run in about 10+ years. they poured marvel in it, let it sit for a day, cranked it over by hand, put more in. they repeted this process a few times to free the rusted pistons. about the 3rd day or so, they went to start the tractor. and it started right up, like it had run the day before, but with a bit of smoke from the marvel.
have you ever run seafoam as an induction clean thru an iv style drip?
Old 08-29-2009, 01:02 AM   #11 (permalink)
No, yet i've searched the site etc and I bet soaking the rings and grooves is probably the best, short of an engine job.
Old 08-29-2009, 03:20 AM   #12 (permalink)
This is the only product that actually has proven to clean an engine. It takes time, but is a proven fluid.
Bobstheoilguy forums have seen/shown results.
http://www.auto-rx.com/
Old 08-29-2009, 08:09 AM   #13 (permalink)
I'll look for it but that seafoam is going in first.
Thanks
Old 08-29-2009, 01:39 PM   #14 (permalink)
Thanks
You can only buy it online.
Old 09-02-2009, 12:24 AM   #15 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
The 4afe/7afe are plagued with this as well. The 20v I rebuilt had several oil holes plugged up, so I had to clean up the pistons and clean all the oil passages on each piston with a pick and a ring groove cleaner. Lots came out as the previous owner wasn't religious on oil changes.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
