That is common on 8th gen Corollas that have a bad exhaust donut between the exhaust manifold and the downpipe or between the downpipe and the catalytic converter.
Makes a funny noise when accelerating hard and sounds like a NASCAR stock car when you run through a puddle big enough to splash water onto the under carriage.
Could also be an obstruction in the induction system - water or other junk stuck in the resonator cavity or in the airbox.
But from your description (louder when it gets wet or when cold) - sounds likely to be an exhaust leak (leaky donut). Look for the tell-tale soot discolorration close to the joints/unions on the exhaust system.
