Magnaflow Muffler - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2009, 10:59 AM   #1 (permalink)
View TwoPageAfro's Photo Gallery
Question Magnaflow Muffler
I recently purchased
this this
muffler from a fellow TN member. Everything about it is great but for some reason I feel like I've lost power. It just seems to take more pressure on the pedal. Maybe it's just me but could someone confirm or deny my suspicions?
TwoPageAfro is offline   Reply With Quote
Old 09-02-2009, 11:23 AM   #2 (permalink)
on full afterburner
Gameroom cash: $1345597
In order to know for sure, you would have to dyno your car before and after you installed the muffler.
But generally speaking, if the muffler is all that you changed and you left everything else stock, then only the sound would differ. Had you installed a full catback and nothing else, then you would notice a shift in the powerband towards increasing mid-range to high end throttle reponse, but at the expense of low end torque.
Old 09-03-2009, 12:45 AM   #3 (permalink)
Gameroom cash: $120900
View Milky's Photo Gallery
Originally Posted by TwoPageAfro View Post
I recently purchased this muffler from a fellow TN member. Everything about it is great but for some reason I feel like I've lost power. It just seems to take more pressure on the pedal. Maybe it's just me but could someone confirm or deny my suspicions?
if you just put on a muffler than you may have. i used to have a similar muffler on my car, and according to a friends gtech, it got quicker when i took it off. and sounded better too. also dont forget our engines are a high compression engine. so there for it needs as free flowing exhaust system as possible to make power. anything less will be a restriction.
i am currently running with no muffler, stock resonator, and a gutted cat, with a cheap ebay header. and it screams up top. has decent mid to low range too. but we are dealing with a 1.8l engine. low end will not be great by any means unless your supercharged, have a fast spooling turbo, or a 4.56 final drive like me.
Milky is online now   Reply With Quote
Old 09-04-2009, 04:43 PM   #4 (permalink)
So I've noticed a considerable drop in MPG, not the normal fluctuation. I'm not sure how to diagnose the problem.
The only 'mods' I've done to the car are a generic SRI, new spark plugs and wires, and the addition of the magnaflow muffler. I know having the coil pack in the wrong order could cause similar problems but I believe I have it right.
Could the loss of power I feel be related to the suffering MPG as well?
Old 09-04-2009, 10:14 PM   #5 (permalink)
DjiNN's Avatar
View DjiNN's Photo Gallery
SO after you changed the stock muffler to the Magnaflow muffler you noticed a drop in MPG and power loss? Did you change the spark plugs and wires at the same time as the muffler? Also maybe it could be your SRI considering its pulling in hot engine air.
Subaru Impreza 2.5i Premium Satin White
DjiNN is offline   Reply With Quote
Old 09-04-2009, 10:23 PM   #6 (permalink)
View The ///Man's Photo Gallery
you are flooring it more to hear that sweet sweet 4 cylinder buzz, I understand corollas sound better than ferraris
The ///Man is offline   Reply With Quote
Old 09-04-2009, 10:27 PM   #7 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
dirty maf from an over-oiled cone filter?
Old 09-05-2009, 12:45 AM   #8 (permalink)
hmm. how many miles on your car? i used to have a cheap muffler on my car, and it felt much quicker when i took it off and just deleted it. my mpg also went up. i would say there is some sort of restriction. maybe your cat is beginning to get clogged. mine got progressively slower and slower as the cat got worse. then after i gutted it it felt like a new car. just make sure to do the MIL eliminator from newcelica.org if you dont want any check engine lights.
Old 09-05-2009, 08:44 AM   #9 (permalink)
The spark plugs and wires were before the muffler change. I thought the hot air would barely affect it?
it has 55,000 miles on it.
Old 09-05-2009, 08:49 AM   #10 (permalink)
on full afterburner
I agree. That's a possibility too... driving habits change when one can hear the sound of an engine more.
OP, have you noticed this?
Old 09-05-2009, 09:11 AM   #11 (permalink)
I had read about that but I don't think that's the case here. Power loss was most prominent when going up hills and/or speeding up on the highway.
Old 09-05-2009, 09:21 AM   #12 (permalink)
on full afterburner
What you're experiencing is a loss of exhaust backpressure that can cause loss of low end torque. Corollas come from the factory already near their power and torque peaks and messing with these tight tolerances can result in what you're feeling now. Bigger is not always better.
Since you already have an SRI (increases high end power at the expense of low end torque), the effect is more pronounced and noticeable. This is definitely normal. And what happens a lot of the time when you modify an engine designed for economy.
The only solution now is to do a proper dyno tuning session since your car is most likely lacking sufficient fuel delivery.
But that may result in further loss of fuel economy.
Old 09-05-2009, 09:25 AM   #13 (permalink)
Old 09-05-2009, 11:13 AM   #14 (permalink)
when moving the difference between a cai and sri is neglegable. usually air is forced into the engine bay anyways, so air intake temps are close to the same when in motion.
i wouldnt say it would be because of a loss of backpressure, if the stock cat is still equipt then there should be more than sufficent backpressure to ward off any negetive side effects. you generally only want 3-5psi max backpressure for a naturally asperated car, typically much higher on a forced inducted. you can check this with a engine diagnostic vac/pressure guage. most of the ones come with adapters to measure backpressure before and after the cat via the o2 sensor holes.
http://www.uucmotorwerks.com/html_pr...torquemyth.htm
Old 09-05-2009, 12:54 PM   #15 (permalink)
Well I got the muffler removed today and fitted with a stock one again.
I'll let you guys know how it goes.
