You are not required to pull the bumper - as some have been able to bend the bumper cover far enough away to get at the inner bolt on the headlamp assembly. But be a whole lot easier to pull the bumper cover off.
Look on the bottom of the bumper cover - there are several bolts that you need to get at to remove the cover - don't forget the bolts holding the sides (one lower one to attaches to a bracket, one upper one that attaches to the fender). There are also some bolts on the top - right by the grille. You'll know when you got all the bolts, as the bumper cover will come off very easily. If it is stuck anywhere, you probably missed a bolt.
