strange noise... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2009, 03:38 PM   #1 (permalink)
StefanTRD's Avatar
View StefanTRD's Photo Gallery
strange noise...
coming from the left side of my motor, by the crankshaft.
i've had this noise for awhile now, but it comes off and on, but since last night it seemed to have gotten worse. it sounds like something rattling, but when i turn the wheel left or right, the noise stops.
i'm thinking it has something to do with the pulley or the belt itself, any ideas? it doesn't affect the performance of the car at all, not to my knowledge at least.
(i just got the car tuned up about 2 months ago, nothing was wrong then)
StefanTRD is offline   Reply With Quote
Old 09-09-2009, 12:02 PM   #2 (permalink)
StefanTRD's Avatar
i think i've found the problem. i think it's the power steering pump, the sound seems to be coming from there and it sounds like metal vibrating.. (it's cast iron so it makes sense to be it)
also whenever i turn the wheel the sounds stops, so i do believe i found the answer to my problem.
so how do i fix this? or should i just go to a mechanic
Old 09-09-2009, 02:01 PM   #3 (permalink)
Gearhead
Gameroom cash: $196215
Depends if the steering pump is bad or not. Quick test - siphon some of the powersteering fluid out and take a peek at it. If it has little flecks of metal floating around in the fluid - you are going to be looking at a pretty hefty bill. From your description - sounds like the seals could be going (noise when not loaded, turn the wheel to load the system - noise stops).
Before you condemn the pump - try flushing out all the old fluid with fresh fluid. OEM recommends plain old Dexron II/III ATF (should be marked on the powersteering reservoir cap). Power steering fluid can be used, but you need to get "all" the fluid out before you can make the switch. Toyota used to sell PS fluid that is basically ATF without the red dye - I stocked up on this years ago, not sure if they still have some. Last time I checked, they switched to Accel fluid (clear, viscous, petroleum odor).
Doesn't have to be too complicated - you can siphon out the fluid of the reservoir and do successive fluid exchanges over time (Mityvac or similar works great here) - or you can disconnect the return line and drain it directly into a pan while maintaining fresh fluid in the reservoir (sort of like a transaxle cooler line flushing - can be messy).
Old 09-09-2009, 09:58 PM   #4 (permalink)
StefanTRD's Avatar
so i should basically check my ps fluids first, then if it seems fine flush it out and replace it with the ones you recommended? And if that fails, i should check the seals
