Washer reservoir - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2009, 09:51 PM   #1 (permalink)
NoLa Rolla
gaj1967's Avatar
View gaj1967's Photo Gallery
Washer reservoir
A long time ago someone here mentioned having a leak in their windshield washer reservoir. If I remember correctly it was a pretty pricey replacement.
I found a possible alternative. https://www.surpluscenter.com/item.a...49&item=1-3256 It's a 1/2 gallon tank WITH built in pump. I'm sure it could be easily hooked up to the existing system as long as it fits in the engine bay. All for only $20 plus shipping.
Gil
Did you search, here and on the internet, for your answer first? Chances are it was answered recently.
Re-read your post before submitting. Does it make sense to you?
Don't expect a response in two seconds. Nobody is getting paid for this.
gaj1967 is offline   Reply With Quote
Old 09-09-2009, 10:00 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
or junkyard or just glue the crack closed.
Old 09-09-2009, 10:02 PM   #3 (permalink)
NoLa Rolla
gaj1967's Avatar
Yes, but one from a junkyard might be cracked also and a repaired one can crack again. I just wanted to offer another option.
Gil
Old 09-10-2009, 07:41 AM   #4 (permalink)
Old Fart
Salty_Dog's Avatar
Gameroom cash: $195865
View Salty_Dog's Photo Gallery
http://shop.ebay.com/i.html?_nkw=toy...tank&_osacat=0
Salty Dog
Visit www.TundraSolutions.com
The Web's best site for all information about your Toyota Tundra
Corolla: http://www.cardomain.com/ride/2933753
Tundra: http://www.cardomain.com/ride/2515030
Salty_Dog is offline   Reply With Quote
Old 09-10-2009, 09:27 AM   #5 (permalink)
Gearhead
Gameroom cash: $196215
Cool! Thanks for the heads up. For that price, that is pretty cheap. Was actually looking for something like that, but not for the Corolla.
Old 02-22-2011, 05:49 PM   #6 (permalink)
View mugenpaolo's Photo Gallery
how good DIY for replacing this windshield Reservoir?
mine also just found to be cracked at near the top
mugenpaolo is offline   Reply With Quote
Old 02-22-2011, 05:53 PM   #7 (permalink)
pdq
Gameroom cash: $221400
View pdq's Photo Gallery
It's pretty cake. There's either 1 or 2 bolts to remove and then just unhook the old motor and connect to the new reservoir. Make sure to get the exact same reservoir as replacement though.
pdq is offline   Reply With Quote
The Following User Says Thank You to pdq For This Useful Post:
mugenpaolo (02-23-2011)
Old 02-23-2011, 01:27 PM   #8 (permalink)
thanks, mate!
one questions though, my cracked reservoir is full of washer fluid.
do i need to extract it all out before the replacement?
Old 02-23-2011, 02:18 PM   #9 (permalink)
pdq
It's just windex and water (ammonia) -- mostly harmless. Just get a mop bucket or 5 gallon bucket, and after removing the old reservoir, pour the fluid into the bucket. After installing the new reservoir, pour the bucket of fluid back into the new reserver.
Old 02-23-2011, 02:33 PM   #10 (permalink)
so, at the moment the old reservoir gets disconnected, the fluid won't pour crazily into under-the-hood?
thx again for advices
Old 02-23-2011, 04:08 PM   #11 (permalink)
pdq
Yeah, there's a hose that will spew fluid when you disconnect it, but you should be able to put your finger over it.
Old 02-23-2011, 05:35 PM   #12 (permalink)
thanks again!
just had it done!
easy DIY as you said... more than 10 min. for me tho :p
the difficult part was disconnecting the pump/motor from the old reservoir.
i finally lifted it up in the air, and turned the motor 180 degrees, so that it was easier to be shook out.
the hole is bigger than my thumb though
but it's no big deal, because i just moved the old reservoir away rapidly from the under-the-hood compartment as soon as it got disconnected. only some amount of fluid left there, and made the motor wet.
so i dried it by some paper towel and used a blower to dry it even more to be safe.
got the new reservoir from kragen for 47.99+tax
total cost is about 10 bux more than i could get from rockauto.com
but i guess it's better to replace it sooner since when i found the crack, i actually made quite a few holes while a touched the cracked pieces gently by my fingers. so the fluid might get to some undesirable spots under-the-hood while driving... and dirts might get into the reservoir to clog the pump lines.
i thought it came with a new motor since that's what some of the online places stated... but it didn't... so i think 48 bux for this plastic box is kinda ripped off... good that the original one lasted 12 years, and this new part branded DORMAN has a lifetime warranty.
oh, btw, it didn't come with the little filter right under the cap. so i took the old one and put it in the new reservoir.
Old 02-28-2011, 05:17 PM   #13 (permalink)
View captaincorolla's Photo Gallery
My reservoir also recently experienced a large crack due to dry rot. It was simple to do. There's one bolt on the top. Cranked that off and pulled the tank off the holding bolt. Yeah, once you pull the hose out, it leaks like crazy. But I just turned mine up on it's side. Once it was replaced with a new one, I poured the old fluid into the new one. Unfortunately, the new one did NOT come with a screen. Retain your old screen. Total time was well under an hour. I got mine on eBay for about $35 shipped. It was not Toyota brand, but looks like a perfect match. Dealer wanted $300 to replace with Toyota brand and install! HA!
2000 Silver Corolla LE
Carbon fiber altezzas, reverse indiglo gauges, blue LED interior/swapout, clear corners, xenon headlights/corners, MP3 deck, alarm w/ battery backup & pain generator, mesh grill and repainted exterior.
captaincorolla is offline   Reply With Quote
Old 01-17-2012, 02:20 PM   #14 (permalink)
View Colonius81's Photo Gallery
Canada Wind shield washer fluid reservoir removal
Hey
very grateful this thread was already here, I do not have a cracked reservoir, but what i do have is a dirty reservoir. I noticed the cap for the reservoir was missing and unable to source one from a junk yard locally here, I just bit the bullet and ordered one from the dealership (CDN$ 8.95)
probably a rip off, but I would have spent whatever time and gas money driving around looking for one.
Long story short, I need to disconnect the reservoir and clean it out or flush it out.
With the cap gone, there is oil or grit appearing on the windscreen which is leaving streaks on the window to the point of having to pull over in sleet or snow storms to rub the window clean and try not to use the fluid, just the wiper blades.
So My question
Is there only one bolt visible at the top of the reservoir that needs to be removed in order to lift it free ? ( bar the wiring from hose and battery )
I am a total nube at these kind of things only recently, have i taken an interest into doing any of these types of minimal running repairs myself as opposed to paying a fortune to a garage
but better late than never
99 corolla VE
Colonius81 is offline   Reply With Quote
Old 01-17-2012, 03:14 PM   #15 (permalink)
pdq
Colonius, this is cake. Unbolt the one bolt on the top, pull the reservoir out, unhook the pump from below.
You might want to siphen out the washer fluid beforehand. Otherwise it will spill, which is no big deal because it's just windex & water.
Replace with the new reservoir and you're done.
