ATF quest - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2009, 01:12 AM   #1 (permalink)
View njcamry's Photo Gallery
ATF quest
my 99 corolla w/118k i dont think has ever had a tranny change..i bought it 3 yrs ago...should i do it with this much mileage?...it runs great now
njcamry is offline   Reply With Quote
Old 09-11-2009, 09:31 AM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Still has to be changed, regardless of the mileage. But given the mileage and the possibility that it has never been changed, I would just do a drain and refill first with a pan drop. Most of the bigger chunks, metal shavings will drop to the bottom of the transaxle pan and quite a bit might be stuck to those little magnets on the pan. Since it runs pretty decently, I doubt you have any issues with gumming and deposits internally - a drain and refill of fresh ATF fluid (Dexron II/III or equivalent) would help out. Depending on if is a 3-speed or 4-speed auto - plan on getting 4 quarts of ATF for the drain and refill. Has a filter inside - might also be a good idea to replace that as well.
I would recommend not "flushing" the system at this point - might be too much of a shock to the system and potentially cause some problems (assuming the typical cooler line flusher).
