I'll going to HK in a week and may pick up some NEW parts from the dealer as well. I'm now crossing part numbers on toyodiy (that site is oh so handy
) of the stuff to get. So far the entire rear brake stuff is the same between AE101 and AE111, the axle hub and the o-ring behind it is the same between those two AND ZZE110 (so no need to import them
). And we can get the pads and prop valve from AE92 GTS.
Does the parking brake cables need to be changed?
So one of us doing this conversion also have ABS brakes. how are you going to mount the wheel sensor?
Then again after what I read here (that such upgrades may not help if I can already lock wheels up - I have ABS and can sometimes trigger it), if someone want the conversion more badly than I do, I'll sell to the highest bidder.
Post if you have a wish list or suggestions of what I should get. When I'm done crossing the parts, I'll post their numbers here.
EDIT: No wonder we can gank so much from the AE92GTS - a lot of stuff is similar there! Time to "borrow" the VIN of Ren's GTS so I can hit up my local (Toronto) dealer, hehehe
Anyway, here are the part numbers I got so far:
Rear axle carrier
LH 42305-12140
HK$2944
RH 42304-12140
HK$2944
rear disc brake rotor
42431-12150
HK$1928
rear disc brake backing plate
(AE101/111)
LH 47804-12060
HK$422
RH 47803-12060
HK$422
rear disc brake caliper assembly
RH 47730-12460
LH 47750-12460
rear caliper bolt
90105-10167 4x, available locally
parking brake cable (brake to equalizer)
LH 46430-12290
HK$518
RH 46420-12390
HK$518
pad support plate #1
47716-12020 4x
anti-squeal shim
47744-12080 4x
rear brake hose (2x each)
AE92 GTS: 90947-02541
AE101/111: 90947-02740
Banjo bolts and its gaskets can be sourced locally
Parking brake cable clip: 96991-10080, can be sourced locally
Parking brake clevis pin: 90240-08040, also available locally
Clip to clevis pins - well, can be had for pennies at outlet of your choice
