Originally Posted by Nil
So my understanding is this is being caused by the coolant getting into the engine and getting evaporated.
If that is the case then some gasket is messed up .. can you tell me how much I am looking at for repairs ?
White smoke from a cold start could be from condensation, which is normal. But if you get this after the engine is fully warmed up and it doesn't have the usually gasoline odor - could be either a coolant leak into the engine or heavy oil consumption. You notice that you have to constantly top off the oil or if you notice that coolant is disappearing - that will tell you what might be happening.
If the leak is significant - your motor oil should start taking on the consistency of mayonnaise and or have a lighter color than usual.
Really need to do chemical testing to find out for sure. There are several used oil analysis places that can tell you what type of contamination you have in the motor oil. I personally use Blackstone Labs - good price and quick turnaround.
Headgasket blowing out is not common on the 1ZZ-FE engine, but it can happen. Cost wise, depends on where you live at - but could be anywhere from a few hundred to several hundreds of dollars to fix it. Find out if it is a head gasket leak before you start worrying about how much it will cost.
