Originally Posted by BCbear
Hello all. I have a 1999 Corolla that I've had for a few month's now. It rained heavily the other night and I had to use my defroster for the first time in awhile. What I did notice was my rear window defroster was not clearing the window. My dash light came on but the window was still foggy after a 20 minute drive. I looked around for the wire tab on the side of the window but didn't see one (it was dark out though) to see if somehow it was a loose connection. Is there a way to test the rear defroster elements? Thank you.
you can run a voltage meter between the two lead and check for current. also look at the lines from the inside out, they should appear dark form the inside, if they appear orange from the inside, they are most likely scraped off.
