timing chain tensioner oil leaking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2009, 03:40 PM   #1 (permalink)
Registered User
toyotaauto's Avatar
View toyotaauto's Photo Gallery
my 1998 toyota corolla timing chain tensioner is leaking oil,can some one show me where is the tensioner located and is it hard to change?thanks
toyotaauto is offline   Reply With Quote
Old 09-22-2009, 03:51 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Start off on the passenger side of the car, by the serpentine belt. May have to pull the plastic engine cover off to get a good view at it - but it is on the rear of the cylinder head, looks like a plate held on with two 10mm bolts. Located almost directly above the powersteering pump, to the left of the exhaust heat shield.
Pretty common to have this one leak. Even my 2002 started leaking there recently - as when I checked the oil, it was low a few ounces (car never drank oil before). Looked around and found the chain tensioner was leaking.
Do a search on the forum - there are quite a few posts on what to do to fix it. Not a hard process - have to reset the tension on the tensioner, there are a couple of trick for that. I personally would pull the valvecover off to take a peek at the top engine and double check the valve clearances.
Old 09-25-2009, 10:23 PM   #3 (permalink)
Bdub215's Avatar
Gameroom cash: $317265
View Bdub215's Photo Gallery
i think this might be my problem as well. car has been drinking oil for while but i figured it was just being burned. i got my car on a lift at school and saw oil near the belts on the oil pan so i've got some work to do...
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 01-13-2012, 12:19 PM   #4 (permalink)
View Beekeeper2020's Photo Gallery
location of Timing Chain Tensioner
It is hard to see, but it is on the left side.
From the left side, you can see the timing chain cover in front of you, it is just above the engine block.
Here is a picture of the location:
http://www.paulstravelpictures.com/T...Guide-008.html
Beekeeper2020 is offline   Reply With Quote
