wiring help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2009, 09:08 PM   #1 (permalink)
View youmight's Photo Gallery
Canada wiring help
hey guys I just picked up a piaa p4000 fog/driving light kit and was wondering if someone knows a good place to splice into for switched power to operate the relay.
the kit says to splice into the parking lights which i'm ok with but i dont wanna end up with flashing fogs and dont have the wiring diagram.
does any one have the wiring diagram for a Canadian 2001 corolla?
thanks
youmight is offline   Reply With Quote
Old 09-23-2009, 07:27 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
you can just run the relay with its own switch so you can turn them off and on as you desire, just be sure to run the power to the switch from a switched ignition source so that when you turn the car off and key out the lights go out too.
Old 09-23-2009, 07:34 AM   #3 (permalink)
locatiing switched power
maybe i wasnt clear. i'm trying without the wiring diagram to determine which wire is best to use for switched power.
Old 09-23-2009, 07:52 PM   #4 (permalink)
Bitter's Avatar
you should use the wiring diagram that you're not using to determine that
