Fuel Filter Maintenance - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2009, 04:52 PM   #1 (permalink)
View toyotaman11's Photo Gallery
I know that Toyota does not call for fuel filter replacement on the 98-02's.
However I doubt that a fuel filter lasts the life of a car without being clogged. I was thinking about buying one, but it seems that it is a real pain in the ass to change.
Has anyone changed theirs, and at what mileage?
Rides:
2003 Tacoma Pre Runner SR5 TRD
1998 Corolla LE
toyotaman11 is offline   Reply With Quote
Old 10-01-2009, 08:41 PM   #2 (permalink)
bump
Hasn't anyone ever replaced their fuel filter?
Rides:
1998 Corolla LE
Old 10-02-2009, 07:36 AM   #3 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
it may be part of the fuel pump sending unit inside the tank, i'm not sure. honestly unless you're having a problem and this is the last trouble shooting step or you're over 200k miles its probably fine.
Old 10-02-2009, 12:25 PM   #4 (permalink)
Gearhead
Gameroom cash: $196215
Yup, the filter is part of the pump assembly - you have to get access to the tank first, remove the cover plate, and pull up the whole assembly. Then you have to pull that apart to get at the fuel filter inside, as it is just ahead of the fuel pump. There is a coarse outer pickup "sock" that gets the big chunks, the fuel filter gets the finer stuff.
Unless you know there was some foreign material poured into the gas tank - then there should be no reason to suspect a bad filter. The fuel system is a returnless design, so the pump assembly only filters the gas needed, there is no constant fuel recirculation like before. From what I've read about the workings, the filter is also self flushing - so the chance of it getting clogged up is pretty remote.
But if you've filled up with really suspect gas or accidentally filled up with diesel fuel - that should be clean for the life of the car. Even guys with 200K+ miles on the 1ZZ-FE are still running the original fuel filter. I'm at 153K on my 2002 Corolla and 110K on the 2003 Matrix - both running the original fuel filters. Zero problems with fuel to date.
Old 10-02-2009, 04:01 PM   #5 (permalink)
OK that sounds good.
How about if you tend to ride on empty? Wouldn't the particles at the bottom of the gas tank get clogged in the filter?
Rides:
1998 Corolla LE
Old 10-03-2009, 11:04 PM   #6 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Well everyone and every book says you don't need to change the filter and dealers will tell you that you have to buy a whole new pump assembly. Not true. I have changed my filter with a 20-something dollar oem replacement part. I did it because I had fuel delivery issues and when I compared the filters the old one was heavier so it had something built up in there. Take that as you will. I ordered the part online. -Chris
Chris Corolla S is offline   Reply With Quote
