What's this part?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2009, 06:51 PM   #1 (permalink)
View bimmertt's Photo Gallery
What's this part??
So I was looking closer at my engine because I noticed something pink leaking from the driver side of my engine bay and found this part not bolted down to anything. As you can see, there is an aftermarket intake on the car so I am thinking the previous owner needed to leave this part dangling in order to install it. Can anyone tell me what this is and where it is supposed to go? Also, can anyone tell me what might be leaking from the driver side of my engine bay? THANKS!!
bimmertt is offline   Reply With Quote
Old 10-07-2009, 06:58 PM   #2 (permalink)
Toyota Tech in training!
View Downhillzze110's Photo Gallery
thats your vapor VSV. or vacuum switching valve. you can leave it hanging just don't remove it or you'll get all kinds of CEL.
before you ask a 'how do i...' question answer this for me. do you own a repair manual for it? have you searched the forum for a similar issue?
SEARCH THE FORUM BEFORE YOU POST!
Downhillzze110 is offline   Reply With Quote
Old 10-07-2009, 07:55 PM   #3 (permalink)
Thanks! Do you know if this part has any impact on starting the car?
Old 10-07-2009, 08:09 PM   #4 (permalink)
starting, no. running? very much so. and passing any E-checks you have. if you dont have that part your car WILL NOT PASS an emissions check. although removing it might create a big enough vacuum leak to prevent it from starting but thats only because it vents to the manifold.
Old 10-07-2009, 09:03 PM   #5 (permalink)
Gameroom cash: $199666
View jkg065's Photo Gallery
PINK leaking substance from drivers side? Check for leaking engine coolant
if color is the same as liquid in the overflow container.
'04 Nissan Altima 3.5SE
'08 Corolla CE (wife's)
jkg065 is offline   Reply With Quote
Old 10-08-2009, 08:33 AM   #6 (permalink)
So I took a look at the coolant and it is a pink color. I am not sure where it is leaking from though. It is not coming from the radiator as it seems to be leaking from the rear of the engine. any ideas?
Old 10-08-2009, 10:55 AM   #7 (permalink)
Have the leak checked out for possible worn/loose coolant hoses or metal expansion/freeze plug.
