'02 Drivers window replacement done today.
Simple procedure if you are mechanically inclined.
Taped window up to prevent falling using standard masking tape, 3 strips.
Took door panel off.
Weather plastic crap off.
Then I loosened all the bolts that hold regulator in too give room to pullout motor.
Then I used a ratchet with a T25 bit on it and took all three bolts off that hold the motor to the window regulator. This isnt all that hard, use a mirror too see where the screws are.
I then removed the motor. Put new one in, put in 3 screws holding it to regulator and voila, done.
Then TEST it.
Test Sat.
Put plastic back on, door panel and move on.
