Seat Belt Light, Yes I Searched, Need Info - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2009, 01:30 AM   #1 (permalink)
Shuichi's Avatar
View Shuichi's Photo Gallery
I have a 1999 Corolla CE and the seat belt light blinks when I have the belt buckled. I have searched and read all of the other threads regarding this topic. I know that it is possibly a faulty switch in the retractor mechanism. My question is if I do not fix it, will it effect the airbag deployment in case of an accident? Heres what I mean; If the seat belt light blinks the car may think the belt is not buckled. Will the car not deploy the bags if it thinks the belt is not buckled because it will do more damage to a person who is not buckled up. You catch my reasoning? So if the light blinks, will it affect the airbag deployment?
Shuichi is offline   Reply With Quote
Old 10-20-2009, 11:27 AM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Short answer - the systems are interlinked, but the airbag will still deploy if the appropriate threshold is exceeded. Note that the seatbelt pretensioner will not react, so serious injury could occur. This could be as simple as a short in the wiring, I would get this fixed ASAP.
Old 10-20-2009, 03:00 PM   #3 (permalink)
Shuichi's Avatar
I have the FSM for a 1999 Prism and I did a little more research. The seat belt tensioner has a retractor in it. In case of an accident a signal is sent to the retractor to tighten the belt along with deploying the bags. But from what I have read. The seat belt indicator light doesnt effect the airbags deploying. Now does the retractor have two electrical connectors? One for the seat belt light indicator and one for the tensioner? Or is it one connector for both? Also, If I just short the seatbelt indicator switch in the tensioner to fool the system that the belt is on all the time will this cause the airbag light to indicate a fault?
Old 10-23-2009, 02:01 PM   #4 (permalink)
View jeet09's Photo Gallery
jeet09 is offline   Reply With Quote
Old 10-23-2009, 02:04 PM   #5 (permalink)
same problem with my 1999 corolla VE, it was showing the light even the belt was on and nw its nt showing the light even the belt was nt on. Can anyone help hw can we fix it?
thanx.
Old 10-23-2009, 04:01 PM   #6 (permalink)
View BGToy's Photo Gallery
I have the same issue with my Corolla 98 LE. I wonder what an inexpensive fix could be...
BGToy is offline   Reply With Quote
Old 10-27-2009, 06:15 AM   #7 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
I don't think the buckle light is interlinked with the airbag system. Yes, the pretensioner will activate together with airbags, but that switch on the retractor is just that - a switch.
My DIY for THE fix
These pictures helps explain the mod
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 10-27-2009, 08:13 AM   #8 (permalink)
Thank you! Your guide is fantastic. I will totally give it a shot!
Old 10-27-2009, 03:04 PM   #9 (permalink)
Shuichi's Avatar
My DIY for THE fix
In step 3 of the Switch Wire Rerouting you said that you need to unplug the retractor switch connector, the small white one. I have a few questions. Does the seat belt tensioner have two connectors on it? Meaning, is the small white connector only for the switch, and there is another separate connector for the SRS pretensioner?
Old 10-28-2009, 04:43 AM   #10 (permalink)
Beware of pigs
Buurin's Avatar
Correct. The other one is yellow with a metal piece that swings over it, and is not easy to pull, for a reason. That one is for the pretensioner.
This is the seat belt assembly. It's not hard to tell which one is which.
Buy my parts
Buy my other stuff
Old 10-28-2009, 02:06 PM   #11 (permalink)
Shuichi's Avatar
Thanks, that clears alot up.
Old 10-30-2009, 12:26 PM   #12 (permalink)
View captaincorolla's Photo Gallery
Your DIY is great, but why replace a current part with a different part? Couldn't you just replace the current part that doesn't work? Wouldn't that be cheaper and easier? Am I wrong?
2000 Silver Corolla LE
Carbon fiber altezzas, reverse indiglo gauges, blue LED interior/swapout, clear corners, xenon headlights/corners, MP3 deck, alarm w/ battery backup & pain generator, mesh grill and repainted exterior.
captaincorolla is offline   Reply With Quote
Old 11-24-2009, 02:29 PM   #13 (permalink)
Again, why wouldn't you just replace the factory part that's worn, instead of re-doing the whole thing?
Old 11-24-2009, 08:36 PM   #14 (permalink)
Beware of pigs
Buurin's Avatar
My DIY is essentially a mod to move the seat belt sensing contact to the buckle, making it work just like a 2001-02 Corolla. The new part is needed because it has the contact you need for this to work.
I asked at the dealer about replacing the worn part, and their answer is to replace the whole seat belt for $150. I tried jamming something down there to hold the original contact in, but it never worked for more than a month.
Buy my parts
Buy my other stuff
Old 12-21-2009, 02:21 PM   #15 (permalink)
Following Buurin's great guide above, I was able to mod mu corolla to buckle-switch operation and cured the no-seatbelt problem for good. It was about 3 hours worth of work and I purchased a corolla '01 buckle for $25. Since I don't care about doing it perfectly factory-like, I didn't bother installing quick disconnects or running the cable under the floor. All I did was solder a pair of wires from the pretensioner mechanism to the buckle and hid them under the floor mat of the rear seats. Hardly noticeable and works fantastic! If you are really in hurry and don't care about securely soldered wires, then you could shave off one hour from the work by simply connecting the wires via twist-and-tape method. So, the job could be done in less than two hours with $25 worth of hardware purchase. I feel this is a much better solution than purchasing a new tensioner worth over $150 and then running the same risk of sensor breakage due to poor design.
