Totally screwed up my car last night
Last night I made a huge mistake. I tried to swap out my ignition light on my steering column. It currently had a single LED bulb (#74) and I wanted to exchange with a 74-xHP3 LED bulb (3 High Power SMD LEDs with wide beam angle radially mounted) to increase brightness. When I tried to change the bulb, it started flickering, I smelled 'hot electronics' and gave up and switched back to the original LED. Now the ignition light and dome-courtesy light will not turn off, ever. Whether the car is on, off or the alarm is active/in-active, they won't turn off. I had to remove the ignition bulb and turn the dome light to off. My car is a 2000 Corolla with an aftermarket car alarm. When functioning properly: the ignition and dome light come on when the car alarm is de-activated. They eventually fade to off, or turn off when the car is turned on, or the alarm is activated. They will turn back on, when the ignition is turned to off or a door is opened. Now, they're just on 24/7. When the dome light is set to "door" (which is the method where it won't turn off, period) it's very, very dim. When I change it to "on," it's full intensity.
This is probably less of an LED problem, and probably more of a "Matt screwed something up" or car alarm problem. I also think there's a better possibility it's the car alarm. I'm also thinking it might have something to do with the 'fade' feature my car has for automatically turning the lights off.
LOOKING FOR HELP! I have a friend that runs a shop that specializes in LED swapouts so I am hoping he can a lend a hand.
2000 Silver Corolla LE
Carbon fiber altezzas, reverse indiglo gauges, blue LED interior/swapout, clear corners, xenon headlights/corners, MP3 deck, alarm w/ battery backup & pain generator, mesh grill and repainted exterior.
